If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Trying to scrounge some minor points. Any tricks of the trade for getting the fender Stingray emblems to stay on without speed nuts? I tried using double back tape and a razor to cut out the letters, kind of ugly.
If you don't like the looks of the home made sticky-tape, I would suggest you order a couple of new ones from Trim Parts. I've got them on my '72 and just had a high score regional flight judging.
Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.
Didn't realize new ones come with sticky tape already applied. Thanks
It takes a little time but I have taken the smallest ribbon caulk and stretched it out to a smaller diameter and used it as a backing. After installing you can use a heat gun to warm it a bit-helps stick better.
