Got my car back from the body shop after a looooong time. I am sorting through some mechanical, vacuum and electrical issues that have arisen I since I received the car back.
Main problem is that my brake lights and tail lights are reversed. When I turn on my parking lights, all four tail lights illuminate both filaments in the bulbs as if the brake pedal was depressed and if I use my brakes there is no change in brightness of the tail lights. If the lights are not on at all and I depress the brake pedal, all four tail lights illuminate but not bright like brake lights as only one of the filaments in each of the light bulbs are coming on as if the parking lights were turned on but nothing else.
I can't seem to figure this one out. It would seem something simple since obviously there is power to all the lights. I even switched out a bulb for another 1157 to see if the bulbs were somehow defective. No luck there. I restored the tail lamp housings, but it seems that those plastic connectors at the back of th tail lamps only go in one way. Did I make an error in re-assembling th tail lamps maybe?
Any ideas/help is appreciated. Thanks.
- Mike
- Mike
