Here's my frame after blasting, I found the VIN stamping on left rear, the first "ONE" is upside down, ha, ha
1971 blasted frame Pics
Re: 1971 blasted frame Pics
Hoi Daniel,
Well it looks like you're pretty much starting at the beginning!!
It appears that you have quite a good space to work in.
Is that the body in the background of the second picture?
Good Luck!
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
I am going to purchase a replacement from an undetermined vendor, the one I saw at paragon or zip, the other is toastAttached Files- Top
I think the supplier to all those vendors is Vette Products of Michigan. They stock the parts and ship FAST, it fit perfect. They also built complete frames. Here are some shots of the #1 crossmember on my '65 I replaced. I removed the lower control arm bracket and put the seam under the bracket.
Mike- Top
I primed the frame with Eastwood Epoxy Primer then top coated it with their Ceramic Semi Gloss Urethane.
Mike- Top
Hi Mike,
VERY nice.
I really think a frame and running gear are the best looking part of the car when well done.
Sometimes it seems a shame to cover it up with a body!?!
