1961 Battery Cables - NCRS Discussion Boards
1961 Battery Cables
  • Edward B.
    • January 1, 1988
    • 537
    Re: 1961 Battery Cables
    Originally posted by James Fentules (28893)
    On the '61 negative cable, which starter bolt does it attached to?
    Grounding strap from negative battery terminal attaches to starter mounting bolt closest to right side of car (furthest from engine block). My '61 still has the original terminal connectors as shown in the AIM and are the types with through bolts for adjusting clamping pressure.
    • James F.
      • March 1, 1997
      • 45
      Ed - Sounds like a survivor car. Just to be sure, it would be the bolt right next to the one that holds the road draft tube. We had a Bill Boyd in our late seventies Corvette Club.
      • Edward B.
        • January 1, 1988
        • 537
        #18
        William Boyd played "Hopalong Cassidy," a childhood idol of mine but unfortunately no relation. Boyds of a different feather.
        • Robert I.
          • July 31, 2004
          • 164
          #19
          ;908981]Grounding strap from negative battery terminal attaches to starter mounting bolt closest to right side of car (furthest from engine block). My '61 still has the original terminal connectors as shown in the AIM and are the types with through bolts for adjusting clamping pressure.
          Assembly manual shows that flattened copper cable. Replacement cables for my 62 are two black ring clamp cables. Shouldn't one be red?
          ____________________
          Bob Immler
          • Mike E.
            • February 28, 1975
            • 5139
            #20
            No. In 62 positive was black, negative was brown.
            • Robert I.
              • July 31, 2004
              • 164
              #21
              "No. In 62 positive was black, negative was brown."
              Well, the replacements both look black to me. The negative has an "N" on it, the positive has nothing.
              But thanks anyway.
              Bob Immler
