If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Should my fuel gauge be showing fuel level with the key off and out of the ignition? Thought the needle dropped down to empty when key was off. Dead short??
thanks, All
Leif
