How much rust - NCRS Discussion Boards
How much rust
  • Dale C.
    • November 1, 1999
    • 844
    How much rust
    Is there a way to gauge how much rust on a set of rear springs would be acceptable or safe to reuse? Is any pitting acceptable? I would link pictures but I can't get the manager to load my pictures anymore, at one time it would.
    Dale
    • 15595
    Re: How much rust
    Without pictures my crystal ball gets real cloudy, but I would say: Surface rust = just remove it and refinish the spring and don't worry.
    Pits = new spring leaf or leaves. Pitting will cause cracks to develop as the spring flexes.
    • Stephen L.
      • May 31, 1984
      • 3156
      Re: How much rust
      Dale, Had a similar problem loading photos. Got help from this site. Go to "tools" pull down menu on the bar at the top of this screen. Click on "compatibility settings" and place "ncrs.org" on the list. You should be good to go.
      • Dale C.
        • November 1, 1999
        • 844
        Re: How much rust
        Stephen
        Thanks, I'll try that. Here is the spring. What do you think Terry?
        Dale
        • Harry S.
          • July 31, 2002
          • 5293
          Re: How much rust
          Looks like surface rust to me. Take it apart for a complete inspection. Ah, prior to that check the free arch of the spring. I believe it should be somewhere between 10.5 and 11.5 inches.
          Good Luck.
          • Gene M.
            • April 1, 1985
            • 4232
            Re: How much rust
            Take it apart as Harry says. I had one that looked fine as yours does but disassembly uncovered two leafs that were in two pieces. Kinda had an 11 leaf spring.....
            • Joe R.
              • July 31, 1976
              • 4550
              Re: How much rust
              Dale,
              Take the spring apart and glass bead. Check for pits, cracks, etc under the liners. Order a new set of liners from Bair's. Assemble spring and then check for the arch. The spring will act very differently with new spring liners.
              JR
