C2 64 Steel wheel identification help
  • Thomas S.
    Infrequent User
    • January 1, 2002
    • 3
    trying to ID a Steel wheel its stamped on the inside 15x15 1/2 K and the number 2 stamped below. Unlike the orginal 63 steel wheel which has GM stamped on the resied ridge in the Bolt pattern area . this wheel has K1 stamped on it. It also has the number 20 stamped new the stem hole. Is this a Kelsy hays after market wheel or is it one that was used in 64 ?
  • Timothy B.
    • May 1, 1983
    • 5172
    Re: C2 64 Steel wheel identification help
    Thomas,
    My money is that it's a service replacement over the counter wheel, (K) would be Kelsey (1) would be the plant. Does the back taper like a 63 wheel?
    • Thomas S.
      Infrequent User
      • January 1, 2002
      • 3
      Yes it does. It measures & looks identical ( and is a welded conical ) to the 63. Am planning on using it however Im not sure how may points I'll loose at judging.
      • David L.
        • August 1, 1980
        • 3310
        According to Chevrolet Parts History (for service parts, not assembly line parts) the 63 Corvette wheel, GM # 3825686, was replaced with GM # 3834127 in Jan. 1963 which was then replaced with GM # 3839814 in October 1963 which was then replaced with GM # 3838080 in May 1966.
        Up until about 1966 or so the Kelsey-Hayes wheels were date coded on the "inside" which could not be seen with a mounted tire. After that the Kelsey-Hayes wheels were then date coded in the vicinity of valve hole. Years ago I bought replacement 15" X 5 1/2" wheels (GM # 3838080) at my local Chevrolet dealer stamped "K 1 86" and "1" valve hole "7" (January 7, 1986). The 3838080 wheel does not have the same cross section as the 3825686, 3834127, and 3839814 wheels.
        The 3825686, 3834127, and 3838080 wheels have a hub hole diameter of 2 25/32" (2.78") while the 3839814 wheel has a 2 29/32" (2.91") diameter hub hole. The 3839814 also has a small hole (about 1/8" diameter) in one of the 5 raised areas (between the lug holes) on the front face. I have no idea of what the purpose of this 1/8" dia. hole.
        Dave
        • Thomas S.
          Infrequent User
          • January 1, 2002
          • 3
          David
          Thanks so much for the info. I will use it and measure what I have and compare it.
          Tom
