Cornrows?
  • Stephen W.
    • July 1, 2013
    • 50
    Cornrows?
    "66 L79 Vert #1241-- Deducted in judging for carpet with no cornrows. Have read manuals and searched site-- still don't understand what these are. I even called Al Knoch Interiors-- they said they didn't know, either, but that their carpet sets are "as original". I've read posts debating who makes the best repros, but are they accurate to J P Stevens OEM, including "cornrows"??
  • James B.
    • March 1, 1985
    • 217
    Re: Cornrows?
    Stephen:
    Perhaps this link will give you the explanation you're seeking.
    http://books.google.com/books?id=IjoS3stx2s0C&pg=PA65&lpg=PA65&dq=cornrows +in+auto+carpets&source=bl&ots=j6h5hY3H2N&sig=7mRV BpH3lCM9fEfEd2flgzmu9vU&hl=en&sa=X&ei=1sGxUo4Il-agBKzegsgD&ved=0CI0BEOgBMA4#v=onepage&q=cornrows%2 0in%20auto%20carpets&f=false
    James
      • April 1, 2000
      • 477
      Re: Cornrows?
      To me its a descriptive term referring to the appearance of the carpet loops. Carpet with very distinct and segregated loops looks a bit like the rows of corn on a corncob. Other carpet does not have this distinctive pattern and in extreme cases has more of a cut pile look.
      • Gene M.
        • April 1, 1985
        • 4232
        Re: Cornrows?
        corn on the cob would be a better definition of the appearance, if the judge wrote that it may have been clearer. but you could have talked to the judge about it when he reviewed it with you. if you don't ask it is assumed it is understood. when in doubt........ ask questions, this is a hobby of sharing within NCRS.
        • Alan D.
          • January 1, 2005
          • 2016
          Re: Cornrows?
          No one makes an original like carpet with the corn rows, - NO ONE..!!
          You will need to find an old shop that may have some left over or a junk yard (not publically) with some 60's GM cars. And then there's the double stitching and . .. Just buy a good repo!
            • October 1, 1980
            • 15541
            Re: Cornrows?
            Sorry to disappoint you Alan, but that is just not true.
            Contact Scott Bohannon at Performance Choice a division of MidAmerica Motorworks. scott.bohannon@performancechoice.com
            I am not sure they have all colors in stock, but he will know what "corn rows" are and the proper direction for them to run. The heel pad may still be an issue, however -- unless you have an original for them to sew in. Talk to him, and tell him I sent you.
            • Bob J.
              • December 1, 1977
              • 712
              Re: Cornrows?
              Terry,
              do they have carpet with the clear thread woven in the loops that twinkle under light?
              It is an obvious detail on a C2, just by opening a door and looking at the kick panel carpet.
              Bob
              • Alan D.
                • January 1, 2005
                • 2016
                Re: Cornrows?
                Happy to be wrong! Wait for respond to bob ty
                  • October 1, 1980
                  • 15541
                  Re: Cornrows?
                  Originally posted by Bob Jorjorian (1619)
                  Terry,
                  It is a obvious detail on a C2, just by opening a door and looking at the kick panel carpet.
                  Bob
                  • Ronald L.
                    • October 19, 2009
                    • 3248
                    Re: Cornrows?
                    original black c2 carpet turns reddish when exposed to sun light over 40 years. Very key original tell tale, in that state not sure it twinkles.
                    • James W.
                      • December 1, 1990
                      • 2612
                      Re: Cornrows?
                      I've attached some samples of both Al Knock and ACC midyear Corvette carpet. These samples are sitting on an original 1965 Corvette jack board carpeting. The far right sample from ACC shows the corn rows, the problem with it is that if you could see the sample up close and in a section view the carpet loops are too short as compared to the other samples and the original carpet. I am at the point of needing to make a decision on what carpeting I will put in my 1965 convertible but haven't found any clear choice.
                      Happy Holidays,
                      James West
