C3 Spare Tire Tub Resto - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4099
    I decided to pull my spare tire carrier from the 78, clean and paint tub (just clean no paint to tub) and straps. But curious what others make of these rivets. I have included photos of both sides.
    Also, curious how best to clean the tub. Looks like the car saw a stint on the dirt roads of Georgia (red clay). I have gone through the archives and got some pretty good notes on rivet replacement so I think I'm good there.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
  • Steven B.
    • June 30, 1982
    • 3986
    Re: C3 Spare Tire Tub Resto
    Tom, I have started to do my 12,000 mile, always stored indoors SA and I am beginning with Simple Green, diluted. Hopefully I will not need to go stronger but if so I will not dilute. Your carrier looks like it does not need a major cleaning, just surface. My '78 spent some time in GA, also. Good luck with it! Steve
    • Patrick N.
      • March 10, 2008
      • 954
      Tom, I also used simple green and lightly scrubbed with 000 steel wool to clean my tub. My tub had some over spray from a repaint job that had to be removed which is what lead me to the 000 steel wool. The tube came out great. I have also used the green and maroon 3M pads on the under body of my car and that did a good job cleaning the fiberglass nicely as well.
      My rivets were very corroded / oxidized. I drilled them all out, refinished the metal strap. I have a pneumatic rivet gun and re-riveted the bracket back to the tub with rivets from one of the repo suppliers. I was very happy with the results- for very little effort, the results were great.
      Best,
      Pat
      • Scott S.
        • March 1, 1979
        • 747
        Tom, Your rivets are replacements called pop-rivets. You can see the marks where Bubba ground off the originals. The correct rivets are available form Corvette Central or Paragon. I could do them for you at Corvettes of Carlisle. Just let me know.
        Scott
        • Tom R.
          • June 30, 1993
          • 4099
          Thanks Scott...they looked suspicious but just wasn't sure. They must have beat the crap out of it to have to replace the rivets. What was conflicting was that the bottom side, along with the rust looked rather natural. But than it is a 56k mile vehicle. I may take you up on that offer and spend the time to clean and paint.
          Tom Russo
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • Tom R.
            • June 30, 1993
            • 4099
            Patrick
            you would think aluminum rivets would not oxidize and rust but apparently, as we both see, happens! Sounds like you've got the tools to complete the job but will definitely use your techniques to bring it back...thanks!
            Tom Russo
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Scott S.
              • March 1, 1979
              • 747
              Tom, Just remind me before Corvettes of Carlisle.
              Scott
              scott1956@rogers.com
              • Tom R.
                • June 30, 1993
                • 4099
                Patrick
                That 0000 steel wheel and simple green worked nicely. Still got some spots of black paint, I believe, and not sure whee that came from. I'll try some cleaners I have to see if they will lift the paint.
                Yeah...drilled out without a problem. Probably took 90 minutes to bead blast the strap but got primer drying on it.
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                • Patrick N.
                  • March 10, 2008
                  • 954
                  Originally posted by Tom Russo (22903)
                  Patrick
                  Tom, Glad to hear the job is progressing nicely. I think the tub was one of my favorite jobs because it was so dirty when I started and with little time and effort the results were great. My car spent most of its life in western PA and maybe Ohio so if it was out during the winter I'm sure the road salt did a number on the aluminum rivets. in fact, the metal plates under the car that the seats and seat belts are anchored to had at least half of the rivets not holding due to corrosion. All have been replaced Post pics when done- so we can see the before and after.
                  • Patrick N.
                    • March 10, 2008
                    • 954
                    Patrick
                    BTW- I did use some paint thinner on some red paint over spray that was on my tub to get the stubborn paint off.
                    • Tom R.
                      • June 30, 1993
                      • 4099
                      Yeah...lacquer thinner worked nicely on paint. Any tips for rust stain removal?
                      I painted the straps first in satin black and than in the semi-gloss black. I like the look of the satin black but recognize we judges are looking for some gloss but can't help but think 30-40 years ages the sheen of semi-gloss black to the look of satin.
                      Tom Russo
                      78 Pace Car L82 M21
                      00 MY/TR/Conv
                      • Patrick N.
                        • March 10, 2008
                        • 954
                        Yeah...lacquer thinner worked nicely on paint. Any tips for rust stain removal?.
                        I have not tried this myself, but maybe a light spray of rust converter would turn the stain back to a black color? I think others might have better techniques though.
                        • Jim A.
                          • August 17, 2019
                          • 58
                          Tom, I am doing an off the frame restoration of my 1977 L48. Do you still have any "after" pictures of the spare tire carrier.
                          Attached are my before pictures. My tub is dark in color. The bottom is completely covered with undercoating and the original rivets were ground off and replaced with pop rivets.
                          I have read your original post and the replies.
                          • Jim A.
                            • August 17, 2019
                            • 58
                            Attached are the photos I failed to attach!
                            • Scott S.
                              • March 1, 1979
                              • 747
                              Jim, Not sure what to tell you?
                              My phone # is 905-857-1463
