what is this????? - NCRS Discussion Boards
what is this?????
  • Ross F.
    • August 31, 2004
    • 167
    what is this?????
    I pulled out the passenger side carpet today. Cool thing... found a tag. Uncool thing. .there seems to be some sort of heat shielding that I cant identify. The silver heat shield under the carpet is doubled up. Then there is another layer of heat resistant material on top of a riveted in metal plate. With high temp sealant.
    See photos.
    Is this stock? I cant find any information on this. It also looks like the floor in the foot area has been over heated. No silver insulation down there, only under the passenger seat.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: what is this?????
    Ross,
    Look under the patch and see if the exhaust burnt the follr board, especially if the shield is missing.
    DOM
    • Lyndon S.
      • April 30, 1988
      • 1027
      What year is the car?
        • 43221
        See photos.
        Ross------
        It's not original; it's some sort of repair and modification. What year model and engine is this car? That's important information that you didn't provide in your post.
        • Ross F.
          • August 31, 2004
          • 167
          The floor is actually cut out in that area.
          the heat shield above the cat is still there and seems unharmed. It is a 75 convert
          • Ross F.
            • August 31, 2004
            • 167
            Its the stock L-48
            • Ross F.
              • August 31, 2004
              • 167
              I agree, it cant be stock.. but the carpet is original. And the silver insulation is original, and the added insulation pad looks like factory.
                • 43221
                Ross-----
                Surprisingly, it is stock! I believe you will find the part you pictured on UPC A01 to A12, sheet 5.5. It's GM #362937. In fact, it was once available in SERVICE but was discontinued in November, 1985.
                • Mike E.
                  • June 24, 2012
                  • 920
                  Could it have been a quick fix for the first year a catalytic converter was used? I'm pretty sure in 1976 they went with all steel floor pans on both sides as an "improvement" to keep heat from catalytic converter entering the cockpit.
                  Mike
                  • Ross F.
                    • August 31, 2004
                    • 167
                    Mike,
                    I think you're right. My car has a July 8th build date. And the floors are fiberglass. I guess it was a factory fix
                    • Ross F.
                      • August 31, 2004
                      • 167
                      Thanks Joe,
                      Where can find the documents you referenced?
                        • 43221
                        Thanks Joe,
                        Ross------
                        It's found in the 1975 Assembly Instruction Manual (AIM).
                        • Tory S.
                          • 146
                          My all original '75 convertible has it too.
                          1975 Convertible
                          L-48, 4-spd, FE7, radio delete
                          Original owner
                          NCRS Top Flight Regional 2011, 2013
                          Dallas, TX
                          • Ross F.
                            • August 31, 2004
                            • 167
                            Tory,
                            The 75 model is proving to be a real transition period. I believe earlier versions had fiberglass floors, later versions had steel floors. I particularly appreciate the mass of rivets and the ample application of red RTV.
                              • 43221
                              Tory,
                              Ross------
                              1975 was the first year for the catalytic converter and GM was in a "learning mode" with respect to items associated with it.
