54 Horns - NCRS Discussion Boards
54 Horns
  • Greg G.
    • September 30, 1994
    • 61
    54 Horns
    Need to know the configuration for the wires on a 54 horns, i.e. is there a single wire coming out of the intereior of the horn, or is there a terminal post on the horn that you attach the front wire harness to? are there any part numbers on the horns?
    Thanks in advance
    Greg Gorniak
    Member
    Miami Valley NCRS
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 54 Horns
    the horn wires are apart of the wiring harness,
    the horn wires are black
    the harness comes across in front of the radiator support at the top
    the horn wires drop down to the horns out of the harness.....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Troy P.
      • February 1, 1989
      • 1284
      Re: 54 Horns
      There is a terminal on the horn for the hot wire. The ground wire attaches to one of the bolts that holds the horn to the bracket.
      The horns are the "sea shell" type. The lo note has 687 on it and the high note has 688. Those are the last three digits of the part number.
      These horns were used on a wide variety of 6V GM cars and are not rare. But the Corvette bracket differs from the passenger car bracket. Over the years I have made duplicates of the correct brackets to convert passenger car horns to Corvette horns. Still have some if you need them.
      In any case, even though the horn looks good, test it before you buy it. Many do not work.
