69 427/390hp EXHAUST GASKETS - NCRS Discussion Boards
  • Brad H.
    • January 27, 2009
    • 250
    Guys,
    Does anyone make individual cylinder exhaust gaskets? So far all I have found were the single piece type that have all 4 cylinders included on one gasket and it looks terrible.
    Thanks in advance,
    Brad
    • 15706
    Re: 69 427/390hp EXHAUST GASKETS
    Your engine did not originally have gaskets between the exhaust manifolds and heads. It's a quicky fix for warpage issues. The best way to correct warp is to measure the surfaces for flatness and mill them flat, if required.
    • Brad H.
      • January 27, 2009
      • 250
      Thanks Duke,
      I knew they didn't have gaskets originally but I thought maybe someone made a gasket aftermarket for individual cylinders. If not, I'll try truing up the manifolds.
      I appreciate the help,
      Brad
      • Dick W.
        • 10483
        Permatex Copper silicone will help with the sealing
        Dick Whittington
        • Brad H.
          • January 27, 2009
          • 250
          Thanks Dick, I'll try that. I wasn't sure it would hold up to exhaust heat but I'll check it out.
          Brad
          • Dick W.
            • 10483
            Originally posted by Brad Hood (49930)
            Thanks Dick, I'll try that. wasn't sure it would hold up to exhaust heat but I'll check it out.
            Brad
            I had headers on my 454 dually and could not keep it from blowing gaskets every three or four thousand miles. I replaced the gaskets, coated them with the Coppercoat, and when it was stolen 10k miles later the gaskets were still holding.
            Dick Whittington
