If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Seems as though most are using 215/70-15 or 205/75-15 radials for driver tires on their 67. Anyone using/have used 205/70-15? If so, do they look too small? Photos? Thanks --
I've run 205/70/15 on front and 215/70/15 BFG on rear for years now with no problems - would run 215's on front but w/o power steering the 205's are easier to turn - run 35 psi front 28 psi rear
