Hi Guys
Sorry for the delay in getting the bearing numbers some requested in another thread but I've been very busy. I'm working on a '69 Mustang rear axle set this morning as a favor for someone.
The bearing numbers are the same as the Hyatt and New Departure Hyatt bearings but just make sure they are USA Timken. I have seen guys buy the cheaper bearings or send me arms that were rebuilt by others to find cheaper bearings failed in them.
Ok here you go, also use only CR/SKF seals- yes they cost 3x the imports but are the best.
Inner Bearing(cone) M86649
Inner Race (cup) M86610
Inner seal CR16757
Outer Bearing (cone) LM48548
Outer Race (cup) LM48510
Outer seal CR19803
If you can't find them let me know and I'll get them for you but I think you should be able to find them. Go to a bearing supplier, the chain stores sell them in sets and not all are USA made.
Inner seal CR16757
Outer seal CR19803
