STARTER for block 53737739 - NCRS Discussion Boards
  • Ron R.
    • May 31, 1993
    • 190
    This is needed for my 1963 (NOM). Where can I find this starter which has a 3 bolt pattern?
    Re: STARTER for block 53737739
    Ron -
    The 739 block isn't drilled for a starter. Its starter attaches to the bellhousing (manual transmission) or to the transmission (Powerglide) with three horizontal bolts; the starter is #1107664, available from John Pirkle Jr., www.johnpirkle.com.
    • Cecil L.
      • May 31, 1980
      • 449
      John,
      Correct me if I'm wrong, but I believe the turboglide blocks were drilled for a block mounted starter.
        Originally posted by Cecil Loter (3596)
        John,
        Cecil -
        Yes, they were, and the crankshaft in a Turboglide engine was also unique - it had a MUCH larger machining center hole at the rear to accommodate the much larger pilot on the Turboglide converter. Not many of them built (pass. car only, VERY low volume).
