C1 windshield sealing question - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    Getting ready to put another C1 windshield together and wanted to query you about the latest thinking on what sealant to use and where to put it to ensure it comes out watertight.
    Do you put sealant between the gasket and glass and then between the gasket and the frame too?
    What sealant is recommended?
    As I recall I took out massive quantities of dum-dum from somewhere around the lower frame during disassembly. Should I put dum-dum between the lower frame and the body even thought there is a rubber sealer strip in there or does it go somewhere else?
    Thanks for your input.
    Troy
  • Terry D.
    • May 31, 1987
    • 2691
    Re: C1 windshield sealing question
    Troy Did you check the archives? Seems to me there was a discussion on this a while back.
    • Roger W.
      • January 29, 2008
      • 567
      The Spring 2010 issue of the "Restorer" ,Pg. 10, has an article by Dennis Kazmierzak on a 1957 windshield.
      • Troy P.
        • February 1, 1989
        • 1284
        Thanks for your suggestions.
        • Dennis C.
          • June 30, 2002
          • 884
          Here is a link to another thread with some sealant information.
          https://www.forums.ncrs.org/showthre...ght=Windshield
          Dennis
