I just replaced my engine-side wiring harness with a replacement from Eagle Wire Products.
Much more correct than old harness with correct wire colors, lengths etc.
My car is TI equipped, what do I do with two blue-with-purple-stripes wires that are joined together with a connector.
It appears that this would attach to the positive side of the coil, I don't think that is correct since I tried that and the car would not start.
Disconnecting them solved the problem.
My question: should I cut these wires off or just loop them up with tape out of the way?
. [hint -- the one that comes directly from the ignition switch, through the firewall, stays; the one that comes from the outlet side of the ceramic ballast resistor (on non T.I. cars) gets cut off and the ends taped into the main harness trunk].
