Pilot bearing removal - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 814
    When replacing the clutch in my 67, I replaced the pilot bearing. I knew about using grease to hydraulically remove it but didn't have anything that would fit tightly into the center. I found a video on U-TUBE saying to use bread to keep from making a mess using grease. just wanted to report it worked flawlessly taking less than 15 minutes using a slice and a half of bread. I just used a large bolt that was not all that tight fitting and kept adding bread. Cleanout took about 5 seconds. Had enough left over to make a sandwich!
  • Jim D.
    • 2884
    Re: Pilot bearing removal
    An even easier and less messy way is to tap the bearing with a, IIRC, 5/8" tap. Install a 5/8" bolt and tighten it down. When the bolt bottoms out in the crank, keep tightening and the bearing will walk right out. Total time, a couple mins. tops with no clean up. Never had this method fail.
    • Graeme B.
      • October 23, 2007
      • 213
      Bob , white or multi grain?
      • Ray G.
        • May 31, 1986
        • 1189
        mmmmmmm sandwich !
        Grease method has always worked for us.
        I hope you dance
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12762
          Originally posted by Ray Geiger (9992)
          mmmmmmm sandwich !
          don't like the tast of that greas at all so bread is a much better alternative
          Rob.
          NCRS Software Developer
          • Gary R.
            • April 1, 1989
            • 1798
            Interesting, I have used bread plenty of time soldering copper tubing but didn't think about it for a pilot bearing! Now did you install a non metallic one?
            • Timothy B.
              • April 30, 1983
              • 5186
              Gary,
              What's the purpose of bread with soldering copper?
              • Gary R.
                • April 1, 1989
                • 1798
                Hi Tim
                Old plumbers trick from a LONG time ago. When you open a copper line as you know, you have to have all the water out-otherwise it is not going to solder correctly. If you can work on a pipe with the water completely drained and it's dry it is golden. If however there is moisture in the line you can use white bread, no crust, and pack it in the pipe and it will wic up the moisture in enough time to allow you to solder the joint. When water pressure hits the bread it will blow it out so if used on a faucet pull the strainer off.
                • Timothy B.
                  • April 30, 1983
                  • 5186
                  Got it..thanks Gary.
