If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Greg The following is from the 1986 Corvette Shop Manual Section 9B-11 : 1. Disconnect battery ground 2. Open hatch and remove rear trim panel 3. Disconnect power antenna lead to relay 4.Remove left side trim 5. Remove luggage shade 6. Remove carpet trim, left side, and pull back carpeting 7. Remove left side trim panel 8. Raise vehicle 9. Remove inner fender screws and brace open to gain access 10. Remove antenna ground strap 11. Disconnect plastic nut at top of mast. 12. Remove antenna bracket nuts 13. Remove power lead and antenna lead through body 14. Remove antenna 15.Transfer bracket and ground strap.16. For installation reverse removal procedure. Good Luck Don
I did this project on my '84 a couple of years ago-not a fun adventure. I found some detailed instructions with pics on the 'net which helped.
(just Google '84-'86 Corvette antenna replacement or similar and you should get some links) Even with the details provided it was tough getting at some of the attaching points. Having a lift would make things somewhat easier. I just had to replace the nylon ribbon in mine, as the motor itself still worked, but you still need to remove the whole unit for a repair. The luggage shade replacement was difficult as well; seemed to be logical, but frustrating. Be sure you record/photograph how everything was taken apart-ask me how I know...
