Who makes OEM C4 keys with knockouts? - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    Looking for source of 1990 original keys with knockout. Contacted P Lindahl but he is primarily into the C2 & C3 cars.
  • Keith B.
    • March 7, 2008
    • 928
    Re: Who makes OEM C4 keys with knockouts?
    Have you tried your local GM dealer
    • Dick W.
      • 10483
      You might check with member Pat Kraus. You can contact him through the member's list
      Dick Whittington
      • Erv M.
        • February 21, 2007
        • 445
        Tried to contact him via PM but he does not accept messages.
        • Reba W.
          • 937
          Use the email function under profile. That usually goes through.
          • Keith B.
            • March 7, 2008
            • 928
            I don't think Pat has the ability to do vats. Your local GM dealer can make you a key for less then 15 bucks. All you need is a vin and proof of ownership
            • Jim T.
              • March 1, 1993
              • 5351
              My 1996 owners manual says that when a new Corvette is delivered, the dealer removes the plugs from the keys, and gives them to the first owner. However, the ignition key man not have a plug. If the ignition key doesn't have a plug, there will be a bar-coded tag instead.
              At this moment I don't remember if the dealer gave me any knockouts to my new 1996's keys. My 96's two sets of keys on the two PKE transmitters given to me do not have knockouts.
              • Pat F.
                • April 1, 1981
                • 853
                Here are some photos of knockouts.
                They are from a 1992.
                The third photo shows them with other Corvette Stuff, don't know the year.
                I have all the original keys and FOBs for my 1995. Only one knock out and no bar code on the key with no knock out. Must have got lost somewhere.
                PAT, Central New Jersey and Florida Chapters
                • Ed N.
                  • May 16, 2010
                  • 994
                  "I have all the original keys and FOBs for my 1995."
                  ---- Pat Fullam
                  Pat, are you suggesting that 95's came with more than one fob?
                  Ed Nieves
                  NCRS #51799
                  • Pat F.
                    • April 1, 1981
                    • 853
                    No, only one, as set forth in the Owners Manual.
                    See attached.
                    • Pat M.
                      • April 1, 2006
                      • 1575
                      My original owner 96 came with 2 FOBs, two sets of keys, and two door-key knockouts. Don't know if that's typical, but that's what I got.
                      • Pat F.
                        • April 1, 1981
                        • 853
                        Pat, Chevrolet thought that you were such a nice guy they gave you two FOBs.
                        Look in your owners manual and see what it says in there about the number of FOBs you should have received.
                        The 1995 owners manual says one FOB and that you could order more.
                        • Pat M.
                          • April 1, 2006
                          • 1575
                          Yeah, I know Pat, Chevy loves me. I haven't looked at my owner's manual yet, but if you look at Jim's post above, his original owner 96 LT4 came with two FOBS as well.
                          Also, Jim states the manual says that not all ignition keys came with knockouts, some came with a bar code tag. Mine came with neither, only door-key knockouts. Have you researched if some 96s did not come with ignition key knockouts?
                          • Pat M.
                            • April 1, 2006
                            • 1575
                            Pat, just looked and my 96 manual says I should have one FOB standard, but I got two for whatever reason. It also reads exactly as Jim says regarding the knockouts.
                            • Pat F.
                              • April 1, 1981
                              • 853
                              For all the Folks, on page 2-4 of the 1996 Owner's Manual it states in part "Your Corvette comes standard with one PIKE transmitter. An additional transmitter is optional, and up to three can be matched to your vehicle".
                              So you see Pat, Chevrolet thought very highly of you and sent you an extra PIKE transmitter.
