Brake fluid capacity 1954 - NCRS Discussion Boards
    • 15657
    Re: Brake fluid capacity 1954
    IIRC the '63 brake system capacity is 0.65 pint. A '54 would likely be no more. A quart should be enough to fill and bleed the system. When I flush replace brake fluid I flush a quart through to make sure is thoroughly flushed.
    It's best to use new fluid, but if I have some old fluid around I'll use it first, then flush through the fresh quart. I don't think old fluid will absorb significant moisture if the cap is tightly sealed, and a plastic container will not corrode.
    • David W.
      • May 31, 1990
      • 51
        • 15657
        #18
        Is the '54 master cylinder on the cowl or under the floorboard on the frame like the estwhile Williams family '54 Pontiac Catalina Coupe that was owned for over ten years? I remember that M/C was rather small. To access it you lifted up the carpet and removed a plug on the side of the tranmssion tunnel.
        BTW I also recommend filling or flushiing from the shortest to longest line. That's the quickest way to fill the feed pipe from the M/C to the junction block. I've never understood the reason behind GM's recommendation to go longest to shortest. Either way should work, but it's a matter of which one requires the fewest pedal pumps to fill the system and bleed out all the air.
        • David W.
          • May 31, 1990
          • 51
          #19
          Hi, Duke...The master cylinder on the '54 Corvette is on the left side of the fire wall, under the hood, above the steering column. Easy to get at.
          Dave
