Based on my previous thread, https://www.forums.ncrs.org/showthre...ump-amp-pulley , is there a way to balance or check the balance on a fan/clutch/pulley assembly?
First water pump rebuild lasted about an hour ($100)- ran engine to 5000rpm, water pump bearing grenaded (roller bearings everywhere).
Second water pump rebuild (warranty) lasted about 30 miles - run engine to 5000rpm, fan/clutch/pulley start to wobble. Water pump shaft has play in it. Not sure if the problem is the pump rebuilder or an unbalanced fan/clutch/pulley assembly prematurely wearing the water pump bearing.
I've ordered a new "date correct" water pump ($250), but other than ordering a new fan/clutch/pulley ($400???, it's getting expensive for a lousy water pump repair). Is there a way to eliminate the rotating parts as the problem?
TIA,
Mike
TIA,
Mike
