1954 Wiring Harness
  • Kim F.
    • July 16, 2009
    • 80
    1954 Wiring Harness
    I want to replace the wiring harness in our 1954 Corvette. The car was converted to 12 Volt. I know that the 6 volt wiring will work. None of the gauges work. What do I put between the 6 volt gauge and the 12 volt power?
  • Chris S.
    • January 1, 2000
    • 1052
    Re: 1954 Wiring Harness
    my car was converted to 12v back in the 60's
    all the gauges worked on 12v
    you will need to change the voltage regulator to 12v.
    Grounds good ?
    • William C.
      • June 1, 1975
      • 6037
      Change the lamps to 12V also oil pressure and ammeter will work ok, not sure about temp.
      Bill Clupper #618
      • Kim F.
        • July 16, 2009
        • 80
        Chris and Bill thank you. I will check the ground, light bulbs and gauges too.
        • Chris S.
          • January 1, 2000
          • 1052
          temp is mechanical.....
          • Robert J.
            • October 1, 2004
            • 117
            Put a drop down Resister on your fuel gauge and clock. Cig lighter element will need to be 12v. Change your bulbs to 12v. Don't put in headlights that draw over 30 amps......bj
            Also put in a 12v flasher
