If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Stripped door clip screw holes in doors, solutions?
in my 68 doors, the screw holes for the door panel clips are stripped, so the screws don't tighten. Any tips to fix this? Also, the holes at the top of the doors that the chrome panel screw goes in to (through the panel) seem too big for the screws that come with the kits.
Re: Stripped door clip screw holes in doors, solutions?
Steve, I used a paper clip , I bent the clip into a V-shape and put a small bent at each end of the V shape to keep it from pushing into the inside of door. worked great for that issue.
Steve:
There some stuff called Lightning Bond its two parts. A super glue like sunstatnce with a granular filler. Have used it on my 62 doors works great and can be built up. www.lightningbondglue.com/
Wes
One more tip, chrome trim screws can be purchased with over size shanks. Ex #10 screw with #8 head they can be purchased in various lengths and various combinations of head and shank sizes.
Bill Strobel Owner Independent Towing Fayetteville, NC 1979 Corvette White/Red L-82 4 spd Only 4,200 miles Do It Right or Don't Do It At All
