I hate to even bring it up but I've looked at all the threads, the service manual and the AIM and I can't get the wiper doors to close manually. They are stuck open so as to even prevent me from following the service manual steps of 1st removing the 8 screws of the vent grill and then removing the door. See picture of failed door position. I think the door should now actually move open and close freely because I removed the vacuum actuator. Following an incompetent professional alignment (won't go there but he broke the actuator rod and welded it back, it does work OK) I then attempted one normal wiper activation and ended up with the door stuck open. After this actuation the coffee can looked misaligned with a slight unusual nose down attitude (nose being towards thefront of car), and the doors stuck open. I immediately took the actuator can off to relive this binding pressure and also disconnected the wiper activation limit switch. Wipers work fine while holding the limit switch in and also the lower dash over ride knob stops the blade motion and parks fine.
Dale
Dale
