'69 Drive SHaft Has No Wieghts or Weld Marks - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 525
    Is it unusual for a drive shaft to not have weights or evidence any ever existed? The driveshaft of my '69 BB has none and it doesn't appear it ever did - i.e. I see no weld marks. Unfortunately I have never driven the car with the driveshaft in place since someone replaced the trans with a later model requiring a different driveshaft so I can't speak to whether it causes any vibration.
    Jack
    Jack Ottofaro
  • Paul O.
    • August 31, 1990
    • 1716
    Re: '69 Drive SHaft Has No Wieghts or Weld Marks
    Jack
    Is it unusual yes could it happen yes odds thou would be against that from happening but you never know.
      • 15595
      Jack
      You mean like the wheels with no balance weights on them?
      • Paul O.
        • August 31, 1990
        • 1716
        Terry he is talking about a drive shaft with zero or no balance weights attached or any marks of a weight installed.
          • 15595
          I know what he is asking about. You said "It could happen. Not likely, but it could." And I am suggesting the chances of that are right in line with all five wheels having no balance weights on them. DUH.
          Go play the lottery.
          • Paul O.
            • August 31, 1990
            • 1716
            DUH me no read between the lines missed that one.
              • 15595
              I sometimes get too obtuse. It happens.
              • Jack O.
                • July 31, 1996
                • 525
                Seems there would be some evidence of the weights if they had been welded on but one never knows. I read the archives about balancing the drive shaft and didn't come away with an absolute answer - some concluded that one should put the drive shaft on and see if there is a vibration rather than having it balanced first. There is a shop close to me that claims to do drive shaft balancing so I'll probably give them a call. Thanks for the input everyone.
                Jack
                Jack Ottofaro
                • Gary B.
                  • February 1, 1997
                  • 7014
                  Jack,
                  You could take the drive shaft to a drive shaft shop/fabricator who will have the equipment to check if its in balance. If it doesn't have a problem that needs correcting, I'd assume you got the 1 out xx shafts that didn't need a balance weight. As far I know, the balance weight on a drive shaft can't be seen during judging, so it's not a judging issue. If it does need a weight, it ounds like now is a good time to get it balanced since it's off the car.
                  Gary
                  • Jack O.
                    • July 31, 1996
                    • 525
                    Yep, that's what I'm going to do. Thanks.
                    Jack Ottofaro
                    • Jack O.
                      • July 31, 1996
                      • 525
                      Jack Ottofaro
                        • 43203
                        Jack
                        Jack------
                        Absolutely correct. There is NO WAY that these weights are going to come off without there being some "vestige" of their once-presence.
                        Something else to keep in mind: these driveshafts were originally balanced as an assembly with the installed u-joints. If the u-joints are replaced, the original balance (and weights) may no longer be valid. Whenever u-joints are replaced, the assembly should be re-balanced. In fact, have a competent driveline shop install the u-joints and do the balancing. It's usually not even that expensive.
