If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Can someone tell me what type of finish is on the accelerator rod that the pedal mounts to. I just finished soaking mine in evaporust and it looks like made it had a light grey phospahte finish. Could see little sparkles in the right lighting.
That's what mine looks like and I have no reason to believe it has been refinished. It looks like the same finish as is on original hood locks. I'm sure someone on this board will provide us with the proper name for that finish. Chip.
