56 power top - NCRS Discussion Boards
56 power top
  • Mike M.
    • May 31, 1974
    • 8389
    56 power top
    there were three design 56 power top harnesses.The first design had a TWO terminal deck lid safety switch and the trunk lid safety switches were located on the driver side . The second design harness had a FOUR terminal deck lid safety switch and the trunk lid safety switches were located on the drivers side. The third design harness had a FOUR terminal deck lid safety switch and the trunk lid safety switches were relocated to the pass side. Does anyone have the wiring diagram for the 2nd design harness, assuming its different than the third design. also could use a picture of the power top limit switches located on pass side atop the fuel tank cover. especially need to see the cable that attaches to the toggle switch and the bow assembly. thanks much,mike
  • Mike M.
    • May 31, 1974
    • 8389
    Re: 56 power top
    hey guys, forget the above request. after 2 weeks of screwing with the power top assembly, i finally figured it out. it works slick as snot. thanks for all your help. if it were a little later in the day, i'd celebrate with a couple beasts. mike
    • Vinnie P.
      Editor NCRS Restorer Magazine
      • May 31, 1990
      • 1567
      Re: 56 power top
      It's 5 o'clock somewhere!!!
      • Gary J.
        • April 1, 1980
        • 1242
        Re: 56 power top
        Must be pretty slick. How about a post on you tube?
        • Steven B.
          • June 30, 1982
          • 3990
          Re: 56 power top
          Par topz will make you do that, but I wouldn't call it celebratin'.
