I had to go with a new front clip and have no reference for the mounting position of the feder badges. The original front clip is long gone. I can't figure out the references from body lines in the assembly manual. Can anyone direct me to dimensions or could measure there's and post dimensions?
Front Fender Emblem Placement 1964
Re: Front Fender Emblem Placement 1964
OK, taken from an unharmed-unmolested 63 front end. This measurement is from the center of the rear mounting hole! It is 2 3/4" from the mid line and 13 3/4" from the rear fender edge. You can use the emblem to get the spacing for the holes.
JR- Top
Joe, Kevin, 63 and 64 fender flags are one inch different, 64 being farther foward than 63. Kevin, find a 64 and use it for you template. Also, left and right are slightly different, so be careful.1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Believe the 63 is different than 64. The 64 was shifted forward by 1". See Sec 11-13 sheet 1.00 in 63AIM and Sec 11-13 sheet A1.00 in 64AIM. However I recall a discussion on the issue so verify before drilling.- Top
Dan,
Since you have a 64 please give us the measurements for the emblems both right and left. I'll check the 63 on the passenger side as the measurment was on the drivers side. In the 66 AIM it specifies to cut the stud as close to the nut as possible on the passenger side to clear the heater box. Never heard of that before. Then again the only 66 I have owned didn't deserve a cross-flag anyway!
JR
PS. Checked the passenger side on the 63 and it is exactly 1/4" more forward than the drivers side. This discussion is leading me to believe there was no template to locate these emblems. Could that be true???- Top
Dan,
JR1964 Red FI Coupe, DUNTOV '09
Dan,
Ok, my instinct here asks "WHY"? There's got to be a reason for locating these emblems forward, backwards and different on FI cars. Did the emblems on the FI hit the heater box or were they not centered for the inside bonding strip? What is the rationale here for moving these emblems?
Could it be as I mentioned above that there was actually NO template to locate these and there was some union worker with a drill in his hand ready to locate these. I don't think so! Most would have been verticle with no template!
JR- Top
Dan,
I do in fact have a carb engine. As I look at the AIM, it shows the driver's side mounting. Of course the reference lines mean nothing to me. Nor do I see anything "official" about the passenger side emblem being at a different position. Very confusing! Thanks for all the replies.- Top
Dan1964 Red FI Coupe, DUNTOV '09
And here we go again. There are pictures in Post #11 of an early 64 FI. Just add 1 inch.
- Top
