C2 headlight assembly - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12762
    Should I put some grease on the ball bearing in the retainers when I fit the headlights on the car?
    Rob.
    NCRS Software Developer
    Re: C2 headlight assembly
    Rob -
    The thick felt seal that goes next to the bearing should be saturated in engine oil (and drained until it stops dripping) prior to installation, as noted in the Assembly Manual; that felt seal lubricates the bearing.
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12762
      Rob -
      so no grease on the outside of the ball?
      Rob.
        Nope, no grease on the outside of the ball.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12762
          So just so I understand fully:
          The bearing balls should not rotate in the aluminium holder, it should only rotate on the axle (on my inner and outer axles these are pretty tight (probably due to a little rust and pitting) so I thing there is a need I need to sand the axles a little so they rotate freely)...
          Rob.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17697
            Rob, that's covered in the restoration article I sent you. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • R N.
              • May 31, 2002
              • 640
              Hi Gary,
              If its not too much trouble for you, would you send me that restoration article please. Thanks in advance.
              elkhartblue@gmail.com
