Can't Find #90 Bulb for Parking Brake Alarm-1960 - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1342
    I installed a 2 candle power (cp) #57 bulb and it started out blinking bright and quickly faded to a dull glow. I went to NAPA and O'Reilly's Parts and the #90 bulbs are 50% larger than the original #90. The #90 is a 6 cp bulb. I believe the alarm system needs the 6 cp to operate correctly.
    Any source(s) of correct size #90 bulbs?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Can't Find #90 Bulb for Parking Brake Alarm-1960
    Check with Pete Lindahl. He may have one for you.
    • Dennis C.
      • June 30, 2002
      • 888
      Vettegal has them.
      • Joe M.
        • April 30, 1990
        • 1342
        Thanks for the info Dennis. I asked Pete in Kissimmee and he did not have them; will check Vette Gal.
        • John D.
          • December 1, 1979
          • 5507
          Joe, First time my 63 was judged I got dinged for the large #90 bulb. The little bulbs don't throw off much light but that's what you need for judging.
          Who is Vette Gal? John
          • Ruedi K.
            • December 12, 2011
            • 242
            Vette Gal is Mary Jo Rohner
            • Joe M.
              • April 30, 1990
              • 1342
              The correct #90 bulb is the same size as a dash bulb for a C1, but it is 6 candle power; dash bulbs are 1-2 candle power. #90 was also used in the dome lights on Chevy passenger cars and the Vette courtesy light.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11360
                Joe, Do you have the correct TungSol flasher? On my '59, the light comes on solid for a few seconds, then begins to flash the bulb.
                • Dick W.
                  • 10483
                  If you cannot find the correct configured bulb, here is another old Indian trick (some call it cheating ). Get the amperage draw from the bulb specifications, get the amperage draw for the bulb you are using. Find someone that is good at electronics and let them tell you what resistor you need to make the flasher think the higher amperage bulb is installed. Install the resistor inline (concealed) on the + side of the bulb, voila, you have a flashing bulb!
                  Dick Whittington
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11360
                    Joe, Page 46 of this pdf from the GM Heritage site says the Park Brake Alarm is a #53 bulb, as is the High Beam indicator. The #90 is the Courtesy light bulb with 2 base contacts.
                    Explore more than a century of innovation, automotive leadership, and iconic vehicles at General Motors—a legacy that still drives the future of the industry.
                    • Dick W.
                      • 10483
                      http://www.gmheritagecenter.com/docs...t-Corvette.pdf
                      Yo' be right Rich. I think the confusion comes from the Sylvania catalog (and I would assume others) incorrectly call for the #90 bulb
                      Dick Whittington
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11360
                        Good catch Dick.....I was wondering where that #90 reference came from. It'll never fit in the single contact socket for those applications. It's too big.
                        It's amazing how all these "little things" can be so much of a PITA.
                        I see on the Sylvania website it calls out the #90 for the Brake Warning lamp in error. S/B #53.
                        Here is the spec for the #53 bulb.....
                        For over 100 years, SYLVANIA has delivered lighting expertise with reliable headlights and enhanced visibility—putting light where you need it. Shop LED bulbs, fog lights, and off-road lighting from the #1 aftermarket automotive lighting brand in the USA.
                        And the #57 spec here....(for other dash bulbs)
                        Joe, Try the #53 that may be in the HB indicator socket in your EB flasher to see if it works better.
                        Rich
                        • Jim D.
                          • 2885
                          [ATTACH=CONFIG]44504[/ATTACH] [ATTACH=CONFIG]44505[/ATTACH] [ATTACH=CONFIG]44506[/ATTACH]
                          Good question. The 55-57 cars used a #650 flasher that required a #90 bulb. He should have a #642 flasher and that requires a #57 bulb to be used.
                          • Joe M.
                            • April 30, 1990
                            • 1342
                            I am getting my info from the 1960 Operators Manual. It lists a #90 bulb for the parking brake alarm. I do have the Tung-Sol 642 flasher.
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11360
                              Joe, That must be a error in the OM book. The #90 cannot fit. Jim, in the previous post says the 56-57 uses the 90. It's a much bigger socket with the 2 contacts IIRC.
                              The GM spec says it's a #53 for 1960.
