70 bumper bolt finishes - NCRS Discussion Boards
  • Jeff S.
    • February 1, 2005
    • 73
    I am looking for the correct finish for the bolts on the front bumper support. any picture would really help. Paul if you are out there I don't know if all bolts shouild be zinc or just the end ones. Thankyou for any help Jeff
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 70 bumper bolt finishes
    Jeff
    Most bolts at this time were silver plated and washers also but we have seen an intermix of black phosphate and silver but in most cases all silver.
    So the angle or bat wing silver, center bumper support silver, outer bumper to bumper extension silver, bumper extension to front fiberglass reinforcement the twisted bracket black, bolts at the extension to frame black but have seen silver. It is possible for an intermix of black in all these areas so ether finish should cause no deductions. Hope this helps.
    • Jeff S.
      • February 1, 2005
      • 73
      Once again thankyou for your help Paul. Jeff
