7017375 thermostat housing - NCRS Discussion Boards
  • Don H.
    • December 1, 1981
    • 1494
    As you can see below my thermostat housing is not taking the Iowa winter well. My earlier model units have aluminum housings. This has a repo I bought and obviously is not aluminum. If this is correct a coating is needed. Thanks, Don H.thermostat housing.jpg
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 7017375 thermostat housing
    Donald, they were originally painted dull aluminum while on the manifold including the fasteners with slight overspray on nearby components including the bypass hose and intake manifold. Not the radiator hose, so remove it before painting.
    Dan
    1964 Red FI Coupe, DUNTOV '09
