C1 Replacing Front Engine Mount Cushions
  • Richard H.
    • March 1, 1985
    • 241
    When replacing the front engine mount cushions and jacking up the front part of the engine, is it necessary to disengage the drive shaft and/or loosen t-10 transmission attaching brackets to avoid undue stress on the drive train?
  • Don H.
    • December 1, 1981
    • 1469
    Re: C1 Replacing Front Engine Mount Cushions
    You can definitely leave the drive shaft attached. I would loosen the transmission mount bolts but leave the nut on. I always use a scrap of wood (2x4) between the jack and oil pan. Good luck, Don H.
    • John F.
      • March 24, 2008
      • 2389
      "U" shaped 2x6 like this.
      • Richard H.
        • March 1, 1985
        • 241
        Thanks Donald and John for the information. Richard
        • Larry B.
          • October 22, 2010
          • 254
          John, What are the exact measurements of the oil pan cradle? Thanks, Larry
          • John F.
            • March 24, 2008
            • 2389
            Larry, see photos. It is a 2x6 with the measurements.
            • Richard H.
              • March 1, 1985
              • 241
              John, I found it difficult to read the measurements from the pictures due to their smaller size. Perhaps Larry had the same difficulty. Richard
              • Jim D.
                • July 1, 1985
                • 2882
                3 pieces of 2 X 6 X 9 1/4" long and assemble like the picture shows.
                • John F.
                  • March 24, 2008
                  • 2389
                  The opening inside the 2x6s is 6 1/4" across the bottom and 9" tall inside.
