What is the application for this belt GM3861950 - NCRS Discussion Boards
  • Ralph S.
    • February 1, 1985
    • 935
    Moulded into the belt is GM3861950 XP 54.00 X 380 5- 1990
    • 43255
    Re: What is the application for this belt GM3861950
    Ralph------
    I can't find any Chevrolet passenger car or light truck application for the GM #3861950. So, even though it's a Chevrolet part number, I expect it was used for some other GM car line(s).
    • Dick W.
      • 10483
      I have one back on the rack in the parts room. I cannot remember what it fits, Dayco catalog says it was used in pairs on '69-69
      Dick Whittington
      • Paul O.
        • August 31, 1990
        • 1716
        From what I came up with is 1968 427 Alternator without A/C and P/S.
        • Dick W.
          • 10483
          Sounds about right
          Dick Whittington
          • Henry J.
            • November 1, 1999
            • 457
            It is depicted as Item 8, Option page L36, Sheet A7 in the 68 AIM. It is an alternator belt, positioned on the second belt track.
              • 43255
              Henry------
              Yes, I see now that it is listed in the 1968 AIM for the L-36 application. However, strangely, it was never cataloged by GM as the SERVICE belt for that application. In addition, it was never even classified by GM as a part used for the Chevrolet car line (although other belts of the 38619xx series were). So, a Chevrolet dealer could only have ordered it if the customer specified the part number.
                • 6950
                Ralph, I Googled that part no. it comes up as a 427/390 alt. belt. what year?
                • Ralph S.
                  • February 1, 1985
                  • 935
                  I think i had it on my 69 435hp car at one time.
                    • 6950
                    I would imgane that the alt.and brackets may have been the same on the 69 435 car.
                    • Henry J.
                      • November 1, 1999
                      • 457
                      In 68 and 69, the crankshaft pulley called out in the respective AIM's for L36 is the same: #3921923. Similarly, in 68 and 69, the water pump pulley is the same: #3889372. However, the 68 alternator pulley is #3829387 and the 69 alternator pulley is 3846180.
                      For both model years, there appears to be no different pullies called-out specifically in the respective AIM's for the L71.
                        • 43255
                        Henry-----
                        I believe L-71 used crank pulley GM #3863108. This is a cast iron pulley. The GM #3921923 used for L-36 is a stamped steel pulley.
                          • 43255
                          Edward-----
                          The only PRODUCTION Corvette application as evidenced by the AIM that I can find for the GM #3861950 belt is 1968 with L-36.
                          • Henry J.
                            • November 1, 1999
                            • 457
                            Yes, Joe. I agree. There is ample evidence in the literature that I've reviewed to suggest that you are absolutely right.
                            Although I can't find #3863108 in the 68 and 69 AIMs, it may be included in the "parts list or bill of materials" for the L71 option that is referred to therein.
