Question
When you turn the headlights on the low beams on both side work fine. ( outer lamps )
When you put on the high beams both the two passenger lamps ( inner and outer) come on and none of the lamps on the (drivers) right side come on,
I know the lamps are good because I pulled and tested them,
Could this be a relay ?
Where would be the best place to start, to trouble shoot, meter out ?
