62 What paint for frame and suspension - NCRS Discussion Boards
  • Larry B.
    • October 21, 2012
    • 71
    I havea 62 fuelie with big brakes and big tank.What should the frame ,suspension,rear end and drop in be painted with and where should I get it.I need a right rear backing plate that has the screens and covers. I plan to sandblast the frame and suspension parts any suggestions.
  • Terry D.
    • May 31, 1987
    • 2691
    Re: 62 What paint for frame and suspension
    Larry
    I see you are a fairly new member, welcome aboard. If you are doing a frame off restoration you will need a few books, the ST-12 manual, the 61-61 judging guide, Corvette Restoration by Noland Adams to name a few. Most of the answers you will need can be found in these books. You will run into issues that are not found in your library, that's when this board will become extremely valuable. As for your backing plate, I'd suggest running a want ad in the "Driveline", the powers to be frown on advertising for parts on this forum. As for the frame blasting, search the archives as this topic has been discussed many times with many different answers.
