59 Vin question - NCRS Discussion Boards
59 Vin question
  • Ty T.
    • June 30, 2004
    • 73
    59 Vin question
    On a 1959 are the locations of the body vin on the tag on the door jamb and the top of the frame under the drivers area, or are there any other locations? And is the tag on the door jamb screwed on or riveted. Thanks!
    Ty
  • James G.
    • May 31, 1976
    • 1556
    Re: 59 Vin question
    Tag is held on the ''B'' pilar of the driver door by Two Philips head screws. The same vin number is stamped on the TOP of the chassis about where the driver door closes. With a little effort and a mirror, you can find it. This is a 67 stamp, but you get the idea.
    • Ty T.
      • June 30, 2004
      • 73
      Re: 59 Vin question
      Thank You Jim. So the number is actually stamped in and not stenciled on as it was on earlier years? Also, are those the only 2 spots other than the engine that the VIN is located? Thanks again Jim. I am trying to identify a stolen 59 and I really appreciate the help.
      • Kenneth B.
        • August 31, 1984
        • 2091
        Re: 59 Vin question
        Not sure about C-1'S but later frames had the SN stamped on top of the frame over the rear axle on the drivers side.
        • Edward L.
          • 278
          Re: 59 Vin question
          Vin #'s were never stenciled on the frame. I think you may be thinking of the frame part number and date that was stenciled. On a '59, the frame is the only location where you will find a vin#. The engine stamping with Vin #'s did not start until 1960.
          • Ty T.
            • June 30, 2004
            • 73
            Re: 59 Vin question
            Thanks Ed. The memory is not what it used to be, But now that you mentioned it, I do recall that to be the case. Is there only the one spot on the frame where it is located?
            • William C.
              • May 31, 1975
              • 6037
              Re: 59 Vin question
              See Gessner's response (above) re-location
              Bill Clupper #618
              • Gary C.
                Administrator
                • October 1, 1982
                • 17772
                Re: 59 Vin question
                Ty,
                Only one location as Jim Gessner said, but some frames are double stamped with the same VIN.
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • James G.
                  • May 31, 1976
                  • 1556
                  Re: 59 Vin question
                  I have seen C-1's with a double stamp, but never over the rear axel as C-2's
                  • James G.
                    • May 31, 1976
                    • 1556
                    Re: 59 Vin question
                    Ty,
                    I have photos of C-1 Frame vins and can explain in more detail to help you find it if needed. Email me at jim@vettefinderjim.com or call 909-794-7905 California Pacific Time.
                    • Kenneth B.
                      • August 31, 1984
                      • 2091
                      Re: 59 Vin question
                      I beleave you are right. My 58 only had one SN & it was under the drivers door
                      • Ty T.
                        • June 30, 2004
                        • 73
                        Re: 59 Vin question
                        Hi Jim,
                        Thanks for your help. I will shoot you an email.
                        Ty
                        • Ty T.
                          • June 30, 2004
                          • 73
                          Re: 59 Vin question
                          Jim. I will try to call you tomorrow (Saturday).
                          Thanks!
                          Ty
                          • Wayne G.
                            • April 30, 1984
                            • 143
                            Re: 59 Vin question
                            A question on the screws that hold the vin plate to the door jam. Are the Phillips head screws stainless steel or mild steel?
                            Wayne
                            • Rod K.
                              • 443
                              Re: 59 Vin question
                              Assuming they're the same as '57 (and probably '53-'60), they're probably a medium carbon steel, definitely not stainless, as they're hardened thread cutting type BT #8 X 3/8 pan head Phillips drive.
