Most 1972, 454 cars have what we think of as the normal AIR pump. A few of them had the "1968-style case-mounted pressure relief valve" as the JG states it.
My question to any of you that might have this set-up, does your have the spacer between the pump and the pulley that typically geos on a small block.
I would be interested on the approximate build date of your car as well.
This is another one of those strange things that happened, but not a ton is known about. So, any input would be a huge help.
Thanks for taking a look.
P.S. I have talked to Bill.
