Checking Compression on a 1971 LT-1 With Transistor Ignition - NCRS Discussion Boards
  • Les G.
    • December 5, 2008
    • 158
    I would like to check compression on my 1971 with TI but I want to make sure not to damage the TI unit. Is there a special procedure to do this? You would normaaly just remove the coil wire, would this damage the TI?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Checking Compression on a 1971 LT-1 With Transistor Ignition
    unplug the black box(AMP) or you could do damage to the electronics
    • Patrick B.
      • August 31, 1985
      • 2011
      I have a 70 LT-1 still running on the original TI unit. I just put a jumper from the coil output to ground when I want to turn the engine over without starting it.
      • Clem Z.
        • January 1, 2006
        • 9427
        just make sure the high voltage from the tower does not jump to either side terminal on the coil
        • Patrick B.
          • August 31, 1985
          • 2011
          Pulling the coil wire at the distributor to attach the jumper to ground avoids the possibility of a spark from the tower to either side terminal. Sorry I forgot to mention that detail.
          • Les G.
            • December 5, 2008
            • 158
            When you say coil output do you mean the ignition wire that goes from the top of the coil to the center of the distributor cap. Do you place an alligator clip inside the coil to ground??????
            • Patrick B.
              • August 31, 1985
              • 2011
              I remove coil wire from the distributor. The terminal at the distributor end of the coil wire is shorted to ground with a clip lead. That way it is not necessary to attach the clip lead directly to the coil tower. Clem pointed out that attaching the clip lead directly to the coil tower would risk sparking to the coil side terminals if the alligator clip got too close to one of the side terminals.
              • Clem Z.
                • January 1, 2006
                • 9427
                if you unplug the amp you don't even have to remove the ignition shielding
                  • 6956
                  Clem, sometimes those wire connectors don't like being tampered with after 40+ years, can create problems, top shied is not a big deal and remove of the neg. wire on coil.
