6.70 15 Spare on Steel Wheel - Any idea what this fits? - NCRS Discussion Boards
  • Joseph G.
    Infrequent User
    • December 9, 2009
    • 8
    I am kind of stumped about what this spare fits. It has a non DOT firestone spare on it but doesn't appear to be a Corvette wheel. Does anyone have an idea what it came off of? I was going to use it as a spare for a 63. The back also has 029PH409 molded into it. Thanks!
  • Terry D.
    • May 31, 1987
    • 2697
    Re: 6.70 15 Spare on Steel Wheel - Any idea what this fits?
    Joseph
    Are those numbers on the rim or tire? Are you asking what the tire fits or the rim?
    • Joseph G.
      Infrequent User
      • December 9, 2009
      • 8
      Those #s are molded into the back of the tire. I am trying to figure out what is the correct application for the rim and also whether that tire is a correct tire for a corvette that came with a 6.70-15. I initilally thought it was, but I also read that dates weren't stamped in tires until 68 or 69. If that # molded into the tire is a date code, then the tire was made after any corvette that would've used it as original equipment.
      • Harry S.
        • July 31, 2002
        • 5345
        As far as I know the codes on the tires from the 60's were internal to the company that made the tire. As of yet I have not found an date or anyone that can decipher the tire codes.
        Saying that, if its a 6.70-15 and the WW is the proper width it should judge just fine on a Corvette.
        If the rims does not have the bumps by the valve stem, it's not for a 63 Corvette.
        • Joseph G.
          Infrequent User
          • December 9, 2009
          • 8
          It has the bumps by the valve stem but does not have the nubs around the center for a small hubcap, like the photos of other 63 wheels on here do.
          • Alan D.
            • January 1, 2005
            • 2054
            OK, verify that a "GM" appears on one of the raised areas between the lug nut holes and none of those areas has a small hole (1/8" ?) A 66 (65?) steel wheel will no longer have the nubs. There are a couple of other items also, but the wheel experts will need to cover that.
            Or just dismount the tire and read the date code.
            • Michael M.
              • February 1, 1993
              • 606
              Is the Firestone tire a Deluxe Champion? Looks like a 1965-66 wheel if the size is 15 x 5 1/2.
              • Joseph G.
                Infrequent User
                • December 9, 2009
                • 8
                I believe it is a firestone deluxe champion, I don't have a photo of the sidewall handy that show it so I'll have to double check. I have more pictures attached here.IMG_1420.JPGIMG_1427.JPGIMG_1425.JPG
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  [ATTACH=CONFIG]41347[/ATTACH][ATTACH=CONFIG]41348[/ATTACH]
                  65/6 Corvette wheel..
                  • David L.
                    • July 31, 1980
                    • 3310
                    Since the wheel does not have the "bumps" for the small hub caps and no stampings near the valve it is probably a 65-66 Corvette wheel (GM # 3869156, 15 X 5 1/2 JK). You can measure the gross wheel width using 2 straight narrow boards about 16" long and measuring through the hub hole. A gross wheel width of 6 1/2" would mean the wheel width is 5 1/2". The hub hole diameter should be 2.783" (about 2 25/32"). You will have to take the tire off to see the stamped size, date code and Kelsey-Hayes logo.
                    Dave
