65 power antenna switch - NCRS Discussion Boards
  • Ernest C.
    • July 31, 1991
    • 115
    Can someone please tell me where the plug for the power antenna switch is located. I have a new Lectric Limited dash and rear harness, but cannot locate a plug for the switch. Thank you
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 65 power antenna switch
    Are you talking about the plug under the dash for the switch? If so, it is a flat square block about 3/8 inch thick with three wires.
    • Ernest C.
      • July 31, 1991
      • 115
      Russ, yes that is what I'm talking about. I purchased the dash harness that was new from someone who told me it was for a 65. I now know it was not because I do not have that plug for the switch. Thanks anyway.
      • David L.
        • July 31, 1980
        • 3310
        The power antenna switch is located on the LH trim panel (GM # 3850045) as shown in the 1965 AIM (UPC 1 ASM, sheet D3) & 1966 AIM (UPC 1 ASM, sheet E2). Also see UPC U69, sheet A3. This panel is on the left side of the radio.
        Dave
        • Russ S.
          • April 30, 1982
          • 2163
          I was wrong here. I was talking about the head light switch and you are asking about the power antenna switch. The antenna switch comes with a pig tail attached that then plugs into the wiring harness about 8 inches above the switch.
