I've ordered a set of Diamondback tires. After installation I will have a full front & rear wheel alignment & balance performed. For regular driving should I deviate from the GM 775/15 bias ply tire recommended alignment specs, to accomodate the new radial tires? If so what caster, camber, & toe in, specs would you recommened?
					Diamondback/Michelin X goldline 205/75R15 tires
 Re: Diamondback/Michelin X goldline 205/75R15 tires
 Glen,
 From Duke Williams:
 Touring w/ radial tires
 Front:
 0 deg. camber
 +1.5 deg caster (+2.0 w/pwr steering)
 1/32" toe-in per wheel
 Rear
 -0.5 deg. rear camber
 Sport w/radial tires
 Front:
 as much negative camber as can be achieved up to -1.0 deg.
 maximum positive caster that can be achieved
 Rear
 -1.0 deg. rear camber
 All cross readings should be as close to zero as possible; 1/32" toe-in per wheel is equivalent to 0.133 deg. toe-in per wheel with 27" diameter tires.
 I hope this helps.- Top
 When I ordered and installed my Diamondback redline MichelinX tires on my '67, I didn't change anything in the alignment from the 7.75X15 bias I was running. I have had it on many long trips at 70-75 mph and on twisty mountain roads and it handles and rides great, so much better than those bias ply things. Big Tanks In the High Mountains of New Mexico Big Tanks In the High Mountains of New Mexico- Top
