Wheelwell Surface Finish - 1970 - NCRS Discussion Boards
  • Clark E.
    • March 1, 1991
    • 163
    The JM provides little information concerning undercoating and paint. Appreciate some guidance on the application and type of undercoating front and rear and the paint finish on the radiator support blacket located in the front wheelwells and the access panels on the forward side of the rear wheelwells. Thanks Clark Erlandson 18941
    • 6950
    Re: Wheelwell Surface Finish - 1970
    Clarke, There really is not much under coating on the wheel wells, generally the tops of front fenders and at the rear of the front fenders, No two car were the same so some may have more area coverage. the blackout is much the same a low gloss paint painted in the front, tops, and rear wells on front, as for the rear wheel wells the under coating was on the tops of the wheel wells, and rear splash panels its generally the thickest of the whole car and if you car has seat belt shoulder harnesses those brackets had undercoating on them.
    The radiator lower support bracket was painted a semi to low gloss black, the acess panel in front of rear wheel wells were painted the same.
    If you cars wheel wells has been untouch since the factory did it look closely at it and just copy it. or even better use a good cleaner and just clean it up. theres nothing like the original. I may even be touched up after cleaning.
    • Dick W.
      • 10483
      If you do have to touch it up, use 3M #8964, body schutz coating. Verrrrrry close to what was sprayed on originally
      Dick Whittington
      • Ron G.
        • December 1, 1984
        • 865
        Actually the factory used a product that was manufactured from a company called Allied Corporation. It was aplied on the rear verticle portion of the rear wheel wells and also the mount for the seat belts. The front wheel wells were only covered on the rear verticle portion of the well. An interesting note is that if you observe Bowtie/Survivor Corvettes, about 1" or 2" from the bottom lip on the front wheel wells is where there is no undercoating used. I can appreciate what Clark said regarding that it was the same coating as the radiator suppor, but that coating was not as thick, but rather kind of gummy to the touch. I am speaking from my experience as I not only did the research, but I was able to purchase 95% of all paints/coatings from the original suppliers of the era that were used on most C2 and C3 Corvettes.
        - Ron
        "SOLID LIFTERS MATTER"
          • 3416
          Hi Clark,
          I found a similar amount of black-out on my 71 as Ron described.
          There appeared to be no black-out on the upper surface of the wheel-well, (the underside of the hood surround); nor was there any on the inner side of the front fender, including the bonding strip area.
          I was using simple green to remove the road grime in the wheel-well and did find these labels embedded in the hood surround fiberglass. My 71 is a mid-January built car.
          Hope this helps a bit!
          • Paul O.
            • August 31, 1990
            • 1716
            The labels equate to the 1st week 1971.
            • Clark E.
              • March 1, 1991
              • 163
              Thanks Guys...The body shop the painted the car cleaned the wheel wells to the base fiber glass leaving no "clues" as to the original finishes. Your comments fit well with what I remember from owning this car for 40 years. Unlike so many other refinishing issues it's nice there was no set finite pattern for applying the undercoating. Boy, what you learn from doing the first restoration!
                • 11678
                Clark,
                Follow the link in my signature below to photos of my original 1972. There are some good pictures of the undercoating and blackout if you wish to look for them.
                • Clark E.
                  • March 1, 1991
                  • 163
                  Many thanks Patrick! The pixs are are a huge help identifying the random patterns used by the factory to coat the wheel wells. Appreciate your dedication to the "cause"...Clark
                  • Russ S.
                    • April 30, 1982
                    • 2163
                    But.... You have to buy a special $120 3M applicator gun to spray it.
                      • 15621
                      That stuff used to be available in aerosol cans. Are you saying that is no longer the case? Tell me it isn't so.
                      • Russ S.
                        • April 30, 1982
                        • 2163
                        I guess I will need to do some more checking. I just called the store, gave them the 3M part number that Dickie posted (8964) thinking I would be getting aerosol cans and when they came they are the shape of an aerosol can only larger. You poke a hole in the top and attach the applicator which you need to hook up to air pressure.
                          • 3416
                          Hi Russ,
                          I've been using 3M #08881 rubberized undercoating which does come in an aerosol can.
                          It's a bit thin so I put it on in several coats with drying time between them. I found I can vary the texture by how far from the surface I hold the can. (The further away, the larger the 'pebble'). It does splatter a bit so I do some protective papering first.
                          Have you seen 08881?
                          • Clark E.
                            • March 1, 1991
                            • 163
                            Guys...It took flat tire caused by a cut valve stem due to an incorrectly installed PO 2 wheel cover to "remind" me I have yet to refurbish the wheel wells. UGH. This original post was just over 5 years ago. Anyway, one more request for specifics and I'm back at it.
                            The front wall of each front wheel well has an opening for the outer bumper brace that is covered by a rectangular "rubber" seal shaped to conform to the brace and held to the wheel well by several staples. Was this seal installed before or after the wheel well was painted with blackout? Any overspray on the seal? Thanks...Clark
                            • Bill L.
                              • February 1, 2004
                              • 1403
                              I can say with 100% certainty that the seals for the bumper braces were applied before paint in the body shop. When I stripped the wheel wells of my 70 the seals had red primer, color coat, and then black out.
                              Interesting thing about my 70 is there was almost NO under coating on the driver's side. Passenger side was typical for an original car. If you can save the under coating do it. It was not really that tough. I am glad I did as you need a special gun to shoot anything close to original under coating.
                              Kind Regards,
                              Bill
