Adding refrigerant to 1993 (LT-1) Corvette - NCRS Discussion Boards
  • Joe S.
    • May 31, 1988
    • 3
    I have a need to carefully add (R-12) "yes I have a can left" to my '93 Corvette. Can anyone tell me where (on the car) to attach my refill hose? I have done this on passenger cars and found that the locations vary greatly.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Adding refrigerant to 1993 (LT-1) Corvette
    Low pressure line.
      • 6957
      Joe, find the receiver dryer (silver canister) there should be a fitting on it. as Jim says this is the low side tap.
        • 43281
        Joe------
        Don't add too much or you can ruin the compressor.
        • Jim T.
          • March 1, 1993
          • 5351
          Do not know about the 1993 Corvette, however my 1985's service manual on air conditioning only specifies a "feel test" to tell you when the charge is enough. I really like using my 70's sight glass a lot better.
          • Dick W.
            • 10483
            Feel test is very accurate if you understand it. Undercharged or over charged the evaporator pipe will feel cool, when you reach the proper charge, the pipe will cold, a very sharp feeling cold.. It is hard to describe, but you can tell the difference. Do not add any more refrigerant once the pipe turns cold.
            Dick Whittington
            • Jim T.
              • March 1, 1993
              • 5351
              Dick this information is taken from my 1985 Corvette Shop Manual. If the inlet pipe to the evaporator is cooler than the accumulator surface this is a indication of low charge of refrigerant. Add slight amounts of 16 oz or 1/4 lb until both feel same temp. Allow stabilization time between additions. Then add 420 ml (.88 lbs) or one can additional refrigerant. I am still trying to learn this "feel test" on my 1985 Corvette.
