tele turn sinal switch repair - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2162
    Gentlemen, I have a tele column turn signal switch that the plastic has broken on. I have tried to epoxy it and also tried JB weld. Does any one know of a great product that will really adhere to the plastic as well as to metal, or is it a hopeless endeavor? It is broken in half where the bearing resides. I have thought if I could get something that will adhere to the plastic as well as metal that I would glue the two halves together around and onto the bearing.
  • Dick W.
    • 10483
    Re: tele turn sinal switch repair
    I believe SEMS has a problem plastic epoxy, but it is close to $40 a tube plus the applicator which I believe is a little more.
    Dick Whittington
    • Michael M.
      • February 1, 1993
      • 604
      Russ, it sounds like a thin piece of sheet metal and some small rivets would work better than any epoxy.
        • 6941
        Russ, being in the automotive trade I would think that any expoxy might be a bad idea, Its a high wear item and something that is used a lot, and lever
        has some resistance when moving the turn signal lever. I would think a replacement switch might be the better opiton and that steering column does not dissy. very easy.
        • Russ S.
          • April 30, 1982
          • 2162
          Ed, I did buy a new one and put it in but I was hoping to also save the original one.
          • Russ S.
            • April 30, 1982
            • 2162
            Michael, I will look at it with that in mind. Thanks for the suggestions one and all.
