EOS after break in?
  • Keith L.
    • April 8, 2008
    • 378
    EOS after break in?
    Is there any benifit or reason not to put EOS in after the first oil change after cam break in? I use CJ4 oil with EOS for the break in on a runnng engine stand. It is a flat tappet 69 396 350HP. I guess I am just paranoid about the cam.
  • Joe R.
    • June 1, 2006
    • 1822
    Re: EOS after break in?
    Keith,
    I don't think using EOS after cam break in is a good idea. Too much ZDDP is not a good thing. Just use CJ-4 oil.
    Good luck!
    Joe
      • 15489
      If it has an OE cam and valve springs or something close, you don't need to use EOS after break-in. CJ-4 has more ZDDP than the oil that GM installed at the factory in 1969.
      • Keith L.
        • April 8, 2008
        • 378
        Thannks guys.
