1960 Blow out question - NCRS Discussion Boards
  • Scott S.
    Infrequent User
    • January 1, 2005
    • 26
    Hi,
    I have not posted in quite a while but had a question that may be a little unusual but I will ask it anyway. I have been fortunate and have never had a tire blow out at any speed in my 60 Vette. My question is: Has anyone reading this ever had a blow out at higher speeds (greater than 50mph)? If so, how does a 50+ year old car react to a simple blow out? It has also been a long while since I had a blow out in a new car but is there any significant difference between a 60' Vette and a newer car at higher speeds? Are there any good tips to know?
    I know this is a different kind of question but I always wanted to know and be prepared.
    Scott Scearce
  • Joseph T.
    • April 30, 1976
    • 2074
    Re: 1960 Blow out question
    Not a blowout..but I was driving a '59 when the rear left tire and wheel went flying off at about 70. The car went into a spin and I ended up stopped sideways in the middle of highway 270 near St.Louis. Very scary..never found the wheel and tire. only real damage was a piece of fiberglass knocked out I think in front of the wheel well and a drum flattened.
    Typically Blowouts are not as radical as the heighth difference is not so great...but can pull the car left or right.
    • Doug F.
      • November 1, 1983
      • 322
      i blew out a right front on my 61 a while back, was going about 70 and felt a new vibration so i let off a bit, it blew shortly after that, about 60, sounded like it was gonna tear the nose off, it only bent the splash shield a little, about 20 years ago our old buddy brain futo blew a front tire on his 65 at hiway speed and it took the whole right front off, i no longer run radials that are 4 years or older on my cars and trucks
      • Scott S.
        Infrequent User
        • January 1, 2005
        • 26
        Thanks for the replies guys. This is good to know.
        Scott
        • Robert S.
          • May 31, 1988
          • 81
          And above all, do NOT touch the brake pedal. Back off the throttle slowly and hang on. Right rear went flat at 75 on the interstate.
