If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have a 66 300 HP. The timing tab has been painted so many times I can not make out the degree markings. Can someone give me a measurement of the distance to 6 * BTDC so I can scribe a line. Also, is each mark on the tab 2* or 1*
