C2 Headlight Bucket - NCRS Discussion Boards
C2 Headlight Bucket
  • Paul J.
    • September 9, 2008
    • 2091
    C2 Headlight Bucket
    Is the outboard pivot ball (aka bearing) on the headlight panel (64) pressed onto the pivot shaft? When I look at it closely it looks like its threaded. The AIM implies that it is pressed on and the shop manual does too, but has no description of it. I also can't find anything on it in the archives.
    Paul
  • Jim D.
    • 2883
    Re: C2 Headlight Bucket
    It should be loose on the shaft and is secured with a set screw.
    • Russ S.
      • April 30, 1982
      • 2162
      There is a collar with a set screw-the ball does not have a set screw.
      • Jim D.
        • 2883
        Oops. I forgot to add the part about the collar. It was early with little caffeine on board. The main point is that the ball is loose on the shaft and should easily slide off.
        • Domenic T.
          • January 29, 2010
          • 2452
          Paul,
          The guys are correct and if you need I have those parts out and would be glad to send any pics you need.
          DOM
          • Paul J.
            • September 9, 2008
            • 2091
            Thanks guys, you've been a great help. The ball is frozen on the shaft. I'm going to use a little heat.
            • Hector G.
              • November 1, 2004
              • 234
              Hi Paul, it may take a bit more than heat to loosen up. Just depends on how badly it's frozen on the shaft. It took several attempts on mine to loosen up.
